141 - 160 of 161 Posts
Discussion Starter · #142 ·
PARTS UPDATE 4/20/2022 (I've gone thru the items)
note: if you're going to Belton X and want parts, I can pull them for you and bring them. and if someone else is going close to you and you want him to bring them back, we can do that to
note2: eventually what ever does not sell will be going to the metal recyclers, including the 305 engine block. the block is probably worth more in metal than it is as a rebuild
I now have the vehicle sitting wide open with the engine and tranny pulled 🍻 so parts a lot easier to get to. pretty much whatever you see in the pics is for sale. more pics here...
photos.app.goo.gl
Wimberley Caballero
30 new items added to shared album
photos.app.goo.gl
Car Automotive tire Motor vehicle Vehicle Automotive exterior
Wheel Tire Car Vehicle Plant
Wheel Tire Car Vehicle Automotive tire
as mentioned before, some of these items will be $$ to ship. I've tried to price items accordingly so that item-price + shipping still saves you money, so you can get an OEM part that is no longer made.
I've also found that as these cars get older, the plastic parts get real brittle. Sometimes they look OK until you try to remove them and they break. So while I try to be careful when removing there is no guarantee it will survive. If it doesn't survive, you don't owe me for it. and you don't pay for it until I actually ship it.
Body
Chin radiator spoiler - AVAILABLE , $20
psgr fender - AVAILABLE , $20
hood - AVAILABLE , $20 (as a bonus, you get 5lbs of FREE river dirt from the flood in the hood!)
Rear window - AVAILABLE , $50
Quarter windows - PENDING , $40/set
psgr Door glass - AVAILABLE , $10
Psgr Door - AVAILABLE , $20
Drivers door - FREE (needs a lot of work)
body-mount door hinges - $10/both sides
cab body from the seats forward including floor pan - $50 (I'm cutting off the roof which has rust at the front edge but the rest of the firewall seems rust free)
Under The Hood (305 v8)
Windshield Washer jug - AVAILABLE , $10
Air Filter snorkel Intake - AVAILABLE , $5
Coolant Overflow - junk
Vacuum ball - AVAILABLE , $10
Charcoal canister - junk
Delay Wiper motor - SOLD , $15
...this DOES have Wiper Delay! AVAILABLE , $5
(the wiper delay is this style, Standard Motor Products DS-414 Standard Motor Windshield Wiper Switches | Summit Racing)
various Engine accessory Brackets - AVAILABLE , $10/all
Brake stuff mounted to firewall - $20
Cylinder Heads - $30/pr
Tranny crossmember - $10
Driveshaft - $10
2004R transmission - $80? (probably a good core to rebuild)
Qjet intake - $10
Aftermarket Qjet carburetor - $20 (probably also a good core)
Any other individual pieces off of the engine such as flywheel, fan clutch, balancer, pulleys, etc, just ask
Interior
Front and rear headliner trim piece - AVAILABLE , $5/set
Door sill plates - AVAILABLE , $5/set
tilt Steering wheel and column with GMC horn insert - AVAILABLE , $35
Glove box - AVAILABLE , $5
Instrument gauges - junk
This has a clock in the gauge cluster, which I pulled out, $5
Seat track plastic feet covers - SOLD
SOLD ITEMS
Front grill with Caballero script - SOLD
Front clip, fenders, hood, etc - SOLD
Front Bumper w/bumperettes - SOLD , $120
Body trim for a two-tone (all of it from front to back) - SOLD , $100
Two-piece fan/engine shroud - SOLD
GMC on tailgate - SOLD
GMC Hood ornament (needs work) - SOLD
Rear window trim - SOLD
Front windshield trim - SOLD
Cast Iron Exhaust manifold - SOLD , $30/set
Cruise control transducer - SOLD , $50
Radio, dash surround - SOLD
Radio, mounting bracket - SOLD
Dash wood plaque with Caballero script - SOLD
A/C compressor - SOLD , $40 (cut the condenser radiator off and it was still pressurized, should still be good)
.........(appears to be an aftermarket 4 Seasons compressor)
A/C condenser/radiator - SOLD , $20
Radio - SOLD, $FREE (because it was under water)
Discussion Starter · #145 ·
1987 GMC Caballero, 350, Holley Sniper EFI, 200-4R
I found I'm missing a body mount bolt and the lower bushing. Please check for a good one.
It may be difficult for me to purchase singles of these. However, if you have one each I'll take it
Discussion Starter · #153 ·
that will have to wait until I can get the cab area cut off from the body, probably mid-summer
Discussion Starter · #154 ·
I finally managed to get some "quality time" working on the flood Caballero. I now have both doors, the plastic feet covers for seat rails, the quarter windows, and the passenger fender removed.
my next step will be to remove the steering column and brake booster then cut off the cab in front of the seat rail mounts thru the floor pan. after that I will be cutting thru the seat rail mounts to the floor and hauling the seats out for trash (it's nasty). I'll make one more cut from there behind the seat and pretty much be done.
I'm trying to dig thru this thread and my Conversations to figure out who was asking for stuff. IIRC someone was asking for the plastic feet covers and someone else was asking for the quarter windows. if that was you, let me know.
whatever hasn't sold or been requested by the end of summer is probably going to the metal recycler. So if you want something, even if not listed here, let me know.
UPDATED 6/12/2022
Body
body-mount door hinges - $10/gets you both sides
Windshield Washer jug - AVAILABLE , $5
Cylinder Heads - $20/pr
Driveshaft - $10
exhaust Y pipe - $10
TH350 transmission - $80obo (probably a good core to rebuild)
Qjet intake manifold - $10
Interior
SOLD ITEMS
Discussion Starter · #155 · (Edited)
MAJOR UPDATE: 99% of the stuff has been removed and is now lying loose in the bed of the truck. I'm going to line it all up and start taking pictures. If I haven't sold it off in the next 3-6months it's going to the metal recycler.
still need to cut off the cab.
UPDATED 6/29/2022
Body
Body trim for a two-tone (all of it from front to back) - PENDING (almailhiot) , $100
Quarter windows - PENDING , $40/set (Kruizer)
Psgr Door - AVAILABLE , $10
body-mount door hinges - $10/gets you both sides upper and lower
cab body from the seats forward including floor pan - $40 (I'm cutting off the roof which has rust at the front edge but the rest of the firewall seems rust free)
Vacuum ball - AVAILABLE , $5
Brake booster/master cylinder mounted to firewall - $10
Driveshaft - $10
Interior
Front and rear headliner trim pieces - AVAILABLE , $5/set
SOLD ITEMS
tilt Steering wheel and column with GMC horn insert - SOLD , $20
entire Engine block - SOLD
TH350 transmission - SOLD, $100obo (core to rebuild)
Qjet intake manifold - SOLD
Aftermarket Qjet carburetor - SOLD, $25 (core to rebuild)
Any other individual pieces off of the engine such as flywheel, fan clutch, balancer, pulleys, etc, - SOLD
Discussion Starter · #156 ·
a side note of interest. the buyer also wanted the engine with the tranny even though I warned him it had been in a flood and was probably junk. sold it to him for an extra $50 (I had planned on taking it to the metal recycler)
he calls me back a day later and says 'yeah, it's ratty, but it appears to be an 80's Corvette 350 bored .030 over with 882 heads with an aluminum intake manifold' (not the 305 I thought it was)
oh well, it would have cost me a lot more to salvage it and wasn't worth it to me. told him he got great deal then. he's going to try and salvage the stroker crank. appears to have gone to a good home.
1980 GMC Caballero, 305, TH350
I'm kicking myself for not checking the engine build numbers !!!! I should have looked further after I noticed that the intake was aluminum.
Finally picked up the '81 Caballero from the flood. While there appears to be a lot of good solid parts, I'm pretty sure the engine is toast after being under water and the interior is just flatout disgusting. I doubt you'll want the bench seats, but hey, you never know (those are so nasty that if you pull them out you can have them). We'll know more once we do a pressure wash and get all the dirt (AND THE ANTS) out. I will be pulling the engine (305 v8) out for scrap but I'm sure the cast iron exhaust, accessory brackets, wiper linkage, etc, are good, so if you are interested in something, let me know. Until I really start getting into disassembly, everything is presumed to be in good shape and priced accordingly. If I find it in worse condition, I'll let you know and drop price accordingly.
You can view the general condition of the vehicle at this link...
The front clip has already been spoken for, as well as the rear license plate pocket. Some other items are pending and I do have emails from those folks.
To give you a general idea, I'm going to turn this into a trailer, so everything from cab-forward (except as noted as pending) is available. It's going to be hard to price some of this stuff because I can't guarantee it works (like the radio). So whatever knicky-knacky pieces you might need, just ask.
The list below will be added to as I go along, but if you don't see something here, ask and I'll get back to you about it. Buyer pays shipping.
Final note: I really don't know what some of this stuff is worth. If' you think I'm asking too much, point me to a similar item in like condition selling for less. I'm not looking to make a mint, I just want to get rid of the parts I don't need and give ECC members the opportunity to get some hard to find Caballero items they need or want.
Before I sell anything, I will take close-up pictures of the item and text them to you so you know what you're getting before committing. Don't want unhappy fellow members.
UC=Unknown Condition
Body
Body trim for a two-tone (all of it) - AVAILABLE , $150
Front grill - PENDING
Caballero grill script - AVAILABLE , $65
Chin radiator spoiler - SOLD , $25
Tailgate - PENDING
GMC on tailgate - SOLD , $60
GMC Hood ornament (needs work) - SOLD , $20
Rear window - AVAILABLE , $200
Rear window trim - SOLD (missing a couple of rightside pieces) , $20
Quarter windows - AVAILABLE , $40/set
Door glass - AVAILABLE , $50/set (both unbroken as far as I know, psgr side good)
Front windshield trim - AVAILABLE , $20
Coolant Overflow - Broken
Door Mirrors - $5/set (dented)
Front Bumper w/bumperettes - PENDING , $120
Front License plate bracket - AVAILABLE , $10
Under The Hood
Windshield Washer jug - AVAILABLE , $20
Air Filter Intake - AVAILABLE , $10
Vacuum ball - AVAILABLE , $20
Cruise control mechanism - AVAILABLE , $50
Wiper motor w/linkage - AVAILABLE , $15
A/C components - AVAILABLE , $80 (cut the condenser radiator open and it was still pressurized, should still be good)
Interior
Door sill plates - AVAILABLE , $20/set
Steering wheel and/or column - AVAILABLE , $50?
Radio, dash surround - SOLD , $15
Glove box - AVAILABLE , $20
Instrument gauges - AVAILABLE , $10
Instrument fascia - AVAILABLE , $20
Do you have the ashtray?
