The fuel lines are in pristine condition,and don't want to hack them up.
I'd like to mount a pump under the hood if possible.
My other option is a tank mounted pump.
Anyone running an electric pump in the engine compartment?
Thanks.
Pretty much what I thought..I'm sure I'll figure something out to make a clean adaptation to the existing steel tubing.
Thanks.
mount it to the frame rail near the tank so you dont have to damage your steel lines. use fuel injection hose ,it is stronger and will live better.we mounted my buddies to the frame just at the end of his steel line.
Discussion Starter · #6 ·
Thanks.
I still have to locate my regulator and pressure gauge.
Been moving them from place to place for years..when I finally find an application,they cant be found.:let_it_all_out:
