Accordingto the Bowties Overdrive site, this is supposed to happen with my 700R4 TVE cable.
Step 3 (Adjusting)</B>
Pressing in and holding the 'D' shaped slider release button (pictures at left and above) the inner cable housing (known as the "slider") will be released and freely slide back and forth in a range of approximately one inch. Press the "D" button and pull the "slider" all the way to its outermost (forward towards the front of the engine) position. Positioning the slider all the way out like this makes the next step, installing of the TV cable "ball" into the hole on the TV Made EZ cam, much easier to accomplish.
Well, my cable looks like the attached picture. When I press on the 'D' shaped thing it doesn't move at all and the "slider" won't move either.
Bowties adds
"Once connected, press in the "D" shaped release button, push the "slider" rearward (towards the transmission) as far as it will travel. While holding the "slider" rearward, release the "D" shaped button to "fix" the slider in this rearward most position. From the drivers seat position, press the accelerator pedal all the way to the floor. While holding the accelerator pedal to the floor, have your assistant try to rotate the carburetor/fuel injection linkage further to confirm it's getting W.O.T with the accelerator pedal."
My "slider" is already at the rear most position. Should I just be satisfied?
Jack
Bowties adds
Jack
