1 - 17 of 17 Posts
Steve, thanks for sharing your work efforts. You ported the intake ports to match the gaskets correct? Will you be polishing them as well? Which set of TFS heads did you get and did you do some work on the heads as well?
Earlier this year, I purchased a set of Summit brand heads for my semi-mod 350--SUM-162109. I had found references on other sites which stated Summit brand heads were manufactured by TFS. When I compared specfications between the SUM-162109 and TFS-30410002, they were very close/same with the exception of price (pair vs individual), intake and exhaust runner volumes, max valve lift, and valve guide and seat materials.
At this point, I haven't finished building and running the motor because of a few issues related to wanting to run old school WCFB dual quads. I'll post some pictures in my own thread.
Awesome. I’m running the TFS super 23 heads
I’m not sure if there the same as the summit pieces
I’ve ported the heads and the intake
The intake is nothing more than a standard q jet intake. Made by edelbrock
Discussion Starter #13
I will stall out soon as I have a surgery coming up to remove a tumor
I hope to have this build done soon though
1 - 17 of 17 Posts
