Hey Keyser, have you got any updates about using the 92'-up Crown Vic 21mm rear sway bar in the 5th gen.?
Doug
Doug
well, altho I do go on the paper, it embarasses me greatly to admit that this one isn't mine. Sounds like something I'd come up with, but wasn't.Sir (cough,coughoke
, I thought you posted (maybe on another site!): Ford Crown Vic Rear Sway Bar Rear sway bar from 92'-up Crown Vic., Town Car, Marquis, cop cars is 21mm. Bushings already on the bar [no slit]. Get axle tube braces from a 3rd. gen. Camaro, end links from the ford, you must fab your own flat frame brackets.
This is on the same note paper as the crossmember so I was sure such a good tid-bit was yours!!!
Doug
How strange..a Furd part to be installed kn a El Camino. There oughta be a freakin law......
I found the thread!! It over on MonteCarloSS! : Ford Rear Sway Bar, 4/25/2011, @2:10 AM, Tech. discussion-Rolling chassis.
That bar might be a bit large (21mm) for the 5th gen. El Camino.....?
Doug
Not with my triangulated four-link rear suspension. If I had a torque-arm I might.Anyone think of fitting a Panhard bar from a Camaro / Firechicken to an Elky?
Yeah but, MAP is always interesting!Here is the link but without pictures its almost useless.
http://www.montecarloss.com/community/ubbthreads.php?ubb=showflat&Number=868951#Post868951
LOL Thats for sure.Yeah but, MAP is always interesting!
Doug
