1 - 1 of 1 Posts
Small cracks have started to appear in my padded dash so I would like to replace. Here's my problem: I can lift the right side up but the far left side doesn't budge. The pad has these long plastic tabs that stick through the holes in the top of the dash -- too bad Chevy drilled holes in the dash. I attempted to peer in on the left side when I raise the right side but there is not enough room to see what is holding down the left side. I stood on my head and looked up under the left side of the dash but didn't see anything protruding through the dash. Anyone know if it might just be silicone holding it in place or is there a bolt & nut I'm not seeing? I don't suspect a bolt and nut since the rest of the pad just has long plastic spikes that fit in the dash holes.
Thanks....Dave
1 - 1 of 1 Posts
