I have a 1981 El Camino ss, and the turn lights work. However the other instruments lights do not. Appvalley I replaced two of those bulbs to see if that was the case, it was not. So I’m wondering about what other issues could be Tweakbox happening. I don’t know the first thing about the fuse box and was wondering if that’s where I should try next. Thanks for any input!
definetly check the fuses first. Keep it simple.
The head light switch must be on at least parking lights to have power to the instr fuse.
Also,make sure the headlight switch is turned counter-clockwise so the power will be up to the dash lights
