1 - 17 of 17 Posts
Replaced the body/frame bushings in my 5th gen today. Spent about 45 minutes doing each side - hour and a half total. I was working at a leisurely pace, not difficult at all.
The center one under the door is screwy - had to leave sleeve and washer off.
They all came out! I said a prayer!
The only pain in the butt part is when you have to look up in there to center the washer, you can get an eye full of crap. It is dark, and if you use goggles, it is too dark to see.
What's the bennie?
Hi, Just curious, what's the benefit? The old ones were shot, or will it improve the handling? I've got an '87, just wanted to know if a worthwhile project that'll help,...
- George
Discussion Starter · #5 ·
Probably not a whole lot of benefit. Some people swear that it makes the vehicle "tighter".
My cruck was sagging pretty badly, and I needed a little clearance for my wheel/tire combo. The factory ones are rubber, and depending on their condition the new polyurethane ones can give you a 1/2 in or so.
- George
I did the same on my 80 last year. Although the exterior rubber looked good, I found most of the bushings had greatly deteriorated in the center. My car was a Texas resident most of its life therefore every bolt came out without heat or penetrant. Signifigant handling difference since , kinda like cornering on rails compared to before.
Mine sags a little on the drivers side rear replaced the springs but didn't help. Could it be the body bushings?
Discussion Starter · #9 ·
Did the previous owner weigh 500 lbs? Kidding. The springs are notorious for giving up - but not giving up at the same rate/time.
I'd swap driver and pass side rear springs and see if there is a change. Might be a clue as to whether you have a front or rear spring issue.
That is amazing I have taken body bolts off a few el caminos and never had one go smoothly ,always rusted bolts which half break .
Discussion Starter · #11 ·
The bolts were great, two literally looked brand new except for the rust on the heads.
Well I was 12 for 12 on the ElCo - When I did my Grand National I was 11 for 12. The one glitch there was a rusty cage nut spinning inside the body.
will do.
thanks:beer:
Body bushing change
I'm having a lot of problems with my 82 GMC. Only one nut spun in the cage, left rear. I'm having a hard time getting the old bushings and internal sleves out. Guess I could remove all bolts and jack the body up, last ditch effort.
Body bushing change
Finally got all changed. Number three, under the door, has a different type of fastner. It's almost like a funnel with the threads in the small end. The instructions said to use the 2 1/2 in washer with a 7/16 in hole on top. The funnel type nut wouldn't fit through the washer so I bored it out to 3/4 in and it fit. The nut that spun in the cage, I jacked the body up and kept pressure on it and it finally gave up and I got the bolt out. Didn't have any problem installing the bolt, the cage nut must have jammed up.
1 - 17 of 17 Posts
