Does transmission linkage to U arm Need Cotter Pin/Washer to Lock ???
Or what locks both U-arm and Linkage together???
Do you mean the U-shaped bracket that bolts to the transmission? If so, the shift arm that goes through the U-shaped bracket has a spring clip that goes through the hole in the end of the arm. A washer with a cotter pin should work OK instead.
If that's not what you're asking about, please give more information. How about a pic?
Jack
yes as above it takes a hair pin shaped spring clip and flat washer. a cotter pin will work but dont forget the washer or the link will cut through the cotter pin fairly fast
Jack
Yes thats what i needa cotter pin and washer to secure the linkagage into the U-arm...
