1 - 20 of 24 Posts
any links for a decent 2 fan all aluminum radiator with a heat activation sensor that will fit right into my oem 78 choo choo /malibu front end under 600$-900$ not eBay thanks.
I'm running a radiator from Cold Case and you should call them or look them up. I'm running their aluminum two-row, 1.25 inch tube radiator. It has a tight fitting shroud with two 12 inch electric fans.
Each of those fans on my EC has its own fan controller kit - Four Seasons part number 35879. Each controller and fan has its own power, ground, relay, fuse, temperature sensor, AC compressor control wire and adjustable thermostat. This is not a Cold Case part and each controller is maybe 35 bucks
This gives complete cooling system redundancy while also allowing for separate turn on temperatures.
The summit racing radiator I run in my '82 works pretty well I think. That paired with say a Derale electric fan shroud setup would be right around your $600 mark but would be a killer setup. I can't comment on a fan controller kit as I run the fan activation through my EFI.
Discussion Starter · #4 ·
Can you please explain what the EFI route would be
Discussion Starter · #5 ·
That sounds great except I would prefer one controller I wouldn’t want to make one fan faster and one slower I just want to run temperature reading
can you further explain please I would not like to run dual controllers (they sound cool) and where did you find these controllers I just want a simple thermostat controlled kit
I run a Holley Sniper to run the whole engine as Electronic Fuel Injection. When you run a computer to operate the engine, usually you can add other inputs to it like nitrous operation or cooling fan control.
I saw in the other thread you have a 350. So I'm assuming you probably have a carb and HEI distributor? Really the easiest way to get electric fans working on your setup will be to just run a dual fan controller like the above poster said. They even gave a part number that worked for them and I'd imagine you could probably order it through Summit racing or Amazon.
Discussion Starter · #7 ·
Nice OK he did say it was a tight fit though and I’m looking for an exact fit I don’t really want to be playing Adjust the radiator and shroud zip tied out. I like and appreciate the fuel injected stuff but I got a classic to stay carbureted so definitely I think if you have more links or resources for me I appreciate any help God bless
If you want an exact fit, use this:
This is the fan and shroud setup I use and it fits well. Doesn't come with a fan controller though.
Yes, they make exact fit radiators for your vehicle. Simply call the manufacturers.
As to the fan controller kits - yes, widely available on Ebay, Amazon or Rock Auto. Very simple to install. Less than 40 bucks.
I did not go the EFI fan controller method on my LS swap because I never could get it to work. Even with a relay, I apparently did not get everything I needed from the donor vehicle for my year.
My fan controllers have been on for nearly two years and over 5000 miles with no trouble. They also work perfectly with my Classic Auto Air Conditioning system.
Kicking these fans on separately at different temperatures is also gentler to the alternator.
Discussion Starter · #10 ·
What year are you
Discussion Starter · #11 ·
Good to know
👍 good to know
Discussion Starter · #13 ·
I bit the bullet and purchased the kit came out to 660$ with a digital temp gauge Please tell me I can use my stock hosing that was one main thing I wanted to be able to still use
Discussion Starter · #14 ·
Were you able to use stock hoseing
Discussion Starter · #15 ·
Where are you able to keep your stock hoses
No. It is a different engine behind this Cold Case radiator. But it wasn't hard to figure out suitable new hoses.
71 El Camino SS
Cold Case is the best
1 - 20 of 24 Posts
