1 - 20 of 62 Posts
Venerated Member RIP
Took my first road trip to the East Texas Spring Fling in Tyler with DDD and Steelbeast. What a fun drive we all had.
However, I noticed after sustained highway speed, 70-80mph, my engine temp crept up to approx 200*. Usually right at 180 in town and on short higher speed runs.
It is a new 350 (2500 miles on it), and is running dual electric fans which come on whenever the ignition is on....
My neighbor suggested that the electric fans themselves might be hindering air flow once I'm at highway speeds.
Does that make any sense to anyone out there? :dontknow:
Vendor
Should not hinder air flow, just the opposite. What temperature thermostat are you running?
Why are the fans always on? Seems like a waste. At highway speeds they might be hindering airflow and the alternator has to work harder to generate more juice.
As for the temp issue - I don't know. Is the system pressurizing? Is it full of coolant?
Discussion Starter · #6 ·
System is pressurized, no leaks, has overflow/recovery tank, plenty of coolant. That was the question, could the running fans at highway speed be hindering the air flow.
Thinking about a temperature triggered switch instead of the fans running all the time. I don't trust myself using a manual switch which is why they run all the time - at least I'm sure they are on.
temp trigger is the way to go............some units also shutdown at highway speeds
Vendor
The fans will not hinder air flow unless they are wired backwards or are installed backwards, i.e.., a pusher in place of a puller and vise versa. And indeed, a thermostatic switch is the way to go with the fans, but doubtful that is the solution to your problem. Did you replace the fan and fan clutch with the electric fan or do you still have the fan and clutch installed? What is coolant temps city and highway with a/c on and off, make any difference? What size electric fans, where and how are they mounted?
Discussion Starter · #10 ·
New crate motor, no fan or fan clutch ever on this motor. Dual fans, Flex-a-Lite, 12" each I believe, from JEGS. the shroud the fans are mounted in is a direct fit for the radiator in my 66. It is pulling as it should. Mounting is both rubber isolated hard mounts at the top with 3 additional 'through the radiator' plastic mounts designed for this purpose. The shroud is fit well so as not to loose desired effect.
It has consistently run at 180 or a hair below in heavy or light traffic. It is warm here already and I'm worried about this coming summer in Dallas.
Radiator is original style, but only a few years old and looks new inside and out.
G
I don't think the temp is bad since we were coasting around 90 according to the speedometer app on my phone. I have video proof to show my speedometer was constantly pegged at 80.
The fans should pull enough air on or off the hi-way. I can't remember your rad? 4 core? Aluminum?
The gauge made not be reading right on to?
Just thinking.:dontknow:
Discussion Starter · #13 ·
Not aluminum, but is a 3 row core. Can't remember if it came from Year One or JEGS, been a few years on that purchase. Remember laughing cause they called it something like 'Desert Rat' implying it could handle Texas heat.
Obviously my speedo cable (needle bouncing) is not allowing a good reading, or I need a calibration too . New Autometer gauges and senders where required. Temp sending unit into the cylinder head.
But I had no idea we were going that fast. My speedo never really got above 70, once to 80 maybe.
G
Check out the Spring Fling thread for video proof of the speed.
The radiator is called a "Desert Cooler"
Might be okay for the desert, but not all that effective in the Texas humid air.
Temp sending unit in the head will read a bit higher than the actual coolant temps, as it is close to the exhaust and combustion chambers.
200-210 is NOT a problem at all-----much higher than that, and it can be an issue.
The fans in my 59 are set to kick on at 225 and off at 210/215.
They seldom come on.
Check your timing---might want to bump it up a hair.
50/50 coolant to water is really too much for our climates.
I use one gallon of coolant and that is all.
Water cools better than antifreeze
Vendor
As Bryan stated, 200 is nothing, after all water alone at atmosphere and sea level boils at 212. Add in coolant and a pressurized system and you get the picture. About the crate engine, is it higher performance than that which you removed?
1 - 20 of 62 Posts
