It would be better to start your own thread rather than tag someone else’s. You will have a broader base that you reach. Always Always check your power and grounds first…Speaking of gas gauges, my 85 G body has a weird issue with the sender. It reads half tank in the full position, and empty at the bottom. The gauge reads 0 ohms at empty and 200 at the top, but the gauge doesn't register that. I know a 0-90 is appropriate, but even with 200 ohms I can't get a full reading.
I am doing an in tank fuel pump conversion so I need a separate sender and pump assembly. Any ideas? Thanks!!
