Thanks in advance, and if I have missed a post with this information, please let me know.
86 el camino, stock.
I was hoping to have a bit more time before I dumped a huge wad of cash on this, but because of previous owners kludges, (and a shop tossing on an incorrect new carb) I essentially need to have the top end of the 305 rebuilt, and Im betting that the rest of it needs it as well. Not worth the cash.
I can get a 4.8/5.3L 2000-2002 vortec engine from a Silverado with a matching trans (guessing 4L60E) when I have cash on hand and a way to put it in the back of my truck.
I have researched what I am going to need to get this done, but I lack the knowledge and experience to know what exactly I need. I have upgraded the radiator, and will get a proper fan set up when I figure out the rest of it.
Has anyone had experience or knows of the best swap kits that are available for putting this engine/transmission combination into an 86 G body El camino? I have found several, but I dont know enough to know which is the best bang for the buck, as it were. Any thoughts and links would be much appreciated!
Also, I have found several EFI ready fuel tank/pump combos, but none list the El-camino on compatible models. Is this a model specific issue?
Also, where do I look to find a driveshaft that will fit this upgrade?
Thank you,
Thank you,
