1 - 2 of 2 Posts
dumptruk
i understand i have to remove the backing plates on my 83 rear end. i want to do the blazer upgrade. will i have to pull the axles on the blazer rear end to get at all the parts i need
Yes, the backing plates are bolted behind the axles flanges. I recently harvested both front and rear brakes setups to do the brake upgrade for my 87 Elky. My suggestion is to take as much as you can or whatever the owner of the donor blazer will let you take without increasing the cost above your budget. Be sure you grab the bolts as well as brake cables.
1 - 2 of 2 Posts
