1 - 1 of 1 Posts
86, rear disc conversion. Ive got the lever and screw type. I believe that's what they call it. Its not the separate shoes inside the rotor type.
How do you adjust the E brake cables? Do you set them so the lever touches the stop at rest? Or do they require more adjustment to make the pedal better? My pedal seems OK. Different than drum, but OK.
At moment mine are about 1/8" off the stops. Worried that is too tight and the brakes will heat.
Only about 3 mile test drive so far to seat the pads.
Thanks, Glb
1 - 1 of 1 Posts
