1 - 20 of 20 Posts
Well it depends. If you don't get too far into it's not too difficult. Buy a carb kit and some carb cleaner. Pull the top of the carb, change the needle/seat, accelerator pump, set the float level. Make sure the float is good and not absorbing gas. If in doubt just replace it. Spray some carb cleaner thru all the passages and blow a little compressed air thru them. Then just put it back together with a new gasket. Check that all the linkages move freely, that the butterflies open and close w/o alot of slop. Might not be the highest quality rebuild but should clean it up enough to run decent.
· Deputy Director, Region 3 PA (west)
If you want good results, you have two choices : 1) send it off to a good rebuilder (unfortunately learning nothing in the process), or 2) purchase either the Doug Roe or Jim Ruggles Rochester carb books. If you take the second option, you'll have a reference source that will help for as long as you own a Q-jet equipped vehicle.
Bill
· Deputy Director Region 8
I see you are in Ohio...take it to Chris' Carb Shop in Dayton. He does custom rebuilding, replating, casting, & re-coloring. email: [email protected]. 7718 N. Main St, Dayton, OH 45415. toll free 1-877-498-2272. M-F 7-5, Sat 7-Noon. They know their stuff, Chris is amazing! Charged me $250 for complete rebuild on '87 4-barrel, well worth it, you can't go wrong. I think the last time I check my carb was $400 at Autozone. You might save a few bucks doing it yourself but Chris will guarentee his work for one year! It rans like new! Cheers!
· Premium Member
Mountain Man Carbs cannot be beat and so many of the members can attest to that,including myself. I realize money is tight right now but some things cannot be short changed. At the price of fuel today it doesn't take very long to realize a savings in a properly built carb.. WP
Discussion Starter · #10 ·
How do I fix sloppy butterfly ?
Sent from my LS670 using AutoGuide.Com Free App
· Premium Member
Hmmm, ya know, I have a fantastic q-jet except for one thing: The bushing on the throttle plate is worn out, and it leaks gas/air into #3/5, and it doesn't function well that way. Before it went bad, got 18-20mpg with a 3-spd in the '56.
· Premium Member
DO NOT try to install those bushings yourself unless you have a GOOD drill press - holes have to be drilled exact in size and alignment before they new bushings can go in - one tiny slip and you have a piece of garbage in your hands.
if you can't do that, or know someone you trust to do it correctly for you, send it to a competent rebuilder
· VINTAGE MOTORHEAD
Q jet carbs are tricky to wirk on, imho. Not a good carb to learn on. Pro results are worth the cost.
· Premium Member
Installing the bushings is the easy part, but reaming them to size requires a special reamer, with a pilot on the end of it, to keep the reamer lined up.
When I said special, I also meant expensive:smileyb: The kit for that includes a bunch of bushings, and the tools. for "ONLY" $299.00 !!
That's from Carbs Unlimited, for you folks who want to dive into carb rebuilding.
1 - 20 of 20 Posts
