1 - 2 of 2 Posts
I will attempt to replace the shift lever back onto the steering column soon, but I need to know what is necessary for this job? Somebody put in a B & M floor shifter. Although this shifter may look cool, it takes up valuable passenger space. Plus it is not even close to factory for a possible restoration. I will not start my tyraid on what was this person thinking. I've been told that there is a bracket on the base of the steering column? Any cable, or linkage changes needed for an automatic transmission? I'm sure there is much I'm missing. Any help will help.
Transmission misfire
I cannot help you much but I can feel your confusion. Some one pulled out the 4 speed and replaced it with an automatic. Hope your having better luck than I at finding linkage :?
1 - 2 of 2 Posts
