Hey guys,
I did search this, but didn't see the answer I was looking for. Forgive me if this has been covered before.
I have an 83 El Camino with the 305 engine. I was working on a tune up today, replacing the plugs, wires, distributor cap and rotor.
Having some experience with this much, I knew to be careful with replacing the cap and rotor and the wires. I'm 99.9% sure I didn't switch any wires up and that I didn't turn the distributor when replacing the cap and rotor.
HOWEVER, now it will crank and crank and crank, but will not fire over and start. I checked power to the coil and it's good. I checked for spark at the plugs and didn't find any.
Is this a bad or weak coil by any chance? Is there another way I can check the coil? Is there anything else I should be looking at?
Thanks!
Thanks!
