Both but the horn center's the most irreparable, the plastic viens that run through it are all broken and the acrylic over the GMC logo is cracked with spider viens very badly.
The wheel itself could use a very, very good cleaning and be acceptable yet.
Jeri~
Have been removing the shift lever from my column, and filling the hole, and discovered this.......
Using a small screwdriver, you can (gently!) dig under the edge of that emblem in the center of the horn pad, and it will come right out if you work around the edge of it.
Then, you can put something the same diameter back in there, like maybe an SS emblem, if you can find one that size; or any other emblem you like. (it's almost the exact same size as a 50 cent piece!)
For mine, I have cut out a piece of polished Stainless Steel to the correct size, and will have a jeweler I know engrave a design on it for me.
Of course, everything on my elkie is stock, but you could cusomize it too if ya wanted, I guess.
:dontknow: :secret:
