I have a 71 el camino stock height
I want 20 “ rims on the rear and 18” on the front
What do I need to know to order these
I want the widest ties that won’t rub
I'm sure someone here can help you. I had a 70 model with 255/60/15 tires on the rear and they fit OK with Corvette 8" rally's. They did rub if I tried to use my ElCo as a truck though. Normal driving, no problems. Discount tires comparison would put a 235/40/20 close if the back-spacing were the same. On the front were 225/70/15 making a 225/55/18 pretty close keeping stock backspacing on 7" rallys. Hope this helps!
Try this thread for info.
72 Elco tire and wheel size options
Have you considered putting shocks other than air shocks on and adding air bags inside the rear springs?
I am using 255 50 17 in rear and 225 55 17 in front on real 2 piece Coddington Junk Yard Dogs.
I don't feel a need to go bigger up front.
I might be able to go up to about 295 50 17 in back.
These are on 10 bolt rear end and not on a Ford/Currie 9 inch rear end.
129512
129513
