21 - 25 of 25 Posts
Discussion Starter #21
Hit the front end with the pressure washer. Turns out there were a few bolts under that grease.
131583
131584
I also made some more progress on stripping the frame. Fuel and brake lines are off and the rear end is out.
131586
131587
131588
This is the left rear body mount- pretty happy that this is by far the worst one.
131589
I'm currently shopping around to have the frame sandblasted. I was originally planning to do clean it by hand with an angle grinder, but I think the time and mess I'll save getting it blasted will be worth the cost. Local company was guessing $175 to have it done. I'm planning to do a lot of work before it gets a final finish- boxing in the rails, adding some supports, and eliminating a lot of the holes; thinking I'm just going to rattle can everything when I get it back since I'll be grinding most of it off to weld anyways. I came across this build on gbodyfourm when looking at ideas for frame modifications. I like a lot of what he's done, and plan on using some of his build as inspiration.
Discussion Starter #24
It's slow progress, but at least things are happening. Coil springs came out today- still have all of my limbs. Need to return the spring compressor tomorrow and remove the control arms. Only a few bolts left and the frame will be completely stripped. I'm going to pressure wash the rest of the grease off, and get it out to the sandblaster. Then I can start making improvements!
131746
RK , Good to see you are progressing with your build and we look forward to seeing your progress . We miss that you are no longer in Florida as we enjoyed your company and the zoo stories you told us at Steve Sander`s Gainesville Get Together and 1/4 Mile Run . Keep us in the loop ;)
21 - 25 of 25 Posts
