I'm stumped the truck runs great one day then the next it will run ruff. When running good from a stop hit the gas all I get is power to the wheels it will run like that all day then the next it's not idling good and hesitates on acceleration. Once I'm going it's fine till I stop and go same thing on acceleration. I can't get the TPS to hold at .48v I'm between .36/.41v so that's one problem/ 6BTDC/920RPM'S AT IDLE. My idle same issue one day in park heated up it's at 920 rpm's this is when it's running fine. Next time it's idling at 840 and not steady 840/850/830 I'm not exact on this . I have tightened down the carb/intake manifolds/checked for bad connections/vacuum/new plugs wires are new filter is new carb rebuilt new engine I don't thing there's a sensor that hasn't been replaced.All new grounds. All new dist. with cap and rotor.
ECT. ECT. ECT.:dontknow::dontknow: I'M NOT SHOWING ANY CODES I'M CLEAN THERE.
O.k. here's what I'm doing today after I post this. I'm going to jack up the front end and take off both fender inter wells and check every wire/ground/plug wire/put all new vacuum lines/re-check every bolt fitting/connector every plug connector male and female for worn or broken wires inside the connector itself. I will check all battery wires starter wires. IF THERE'S A WIRE/VACUUM LINE IT'S GOING TO BE INSPECTED AND REPLACED IF NEEDED UNTIL I CAN'T SEE IT OR IT'S FIXED.
Next hopefully with your help I can get this issue resolved so I can put this to rest and move on in life
oke:
I think it's in the fuel/carb area but that's a guess OH NEW FUEL PUMP ALSO. I'm also going to take off my solid fuel line that is almost touching the block all the way down the front of the engine with a breaded line I can re-rough away from all that heat.
If this was a year ago I think I would have got a gallon of gas and torched it and walked away.
Off I go be back in a bit to check what's up here and take a break.
Here's my demeanor now:smileyb: will advise if any change occurs in the process
oke:
