I have a rusty drive-shaft i sanded it now i need somthing to prevent rust and stops rust before paint...
What Products to use on Rusty parts ???
If you want the best use POR-15, go to their website. They make a small starter kit, that would be just right for the drive shaft and a little left over for some other parts. If you want to just paint, get a product called Rust Tough in spray can. I use POR-15, semi-gloss black for underneath.
Did you paint over "rust tough'' with primer and spray paint if so has any of the areas rusted ???Rust Tough is a spray paint, like Rustoleum, but without the fish oils. It is made by Kyron, I called their tech dept many years ago and they recommended it because it was gas resistant. I have been using it on my motorcycle restorations for many years, with great results. I have no idea how it works.
also check out rust bullet. www.rustbullet.com 1-800-245-1600 I used it on all my old problem area's
