Looking to utilize new nuts and bolts for the front upper and lower control arms on my 84' Elky. Does anyone know the sizes of the nuts and bolts. Also need the sizes for the rear upper and lower control arms. Hope someone can help me out here. Thanks. Engine size is a 305 cid if that helps.
I can't tell you the metric stud size, or the length, but the bolt head and the nut are 18mm. Also, the front bolt is a different length from the rear bolt, and I'm pretty sure they're grade 8. What's wrong with the originals?
