1980 with a newly rebuilt .030 over 305, flat top pistons, Edelbrock Performer cam, Performer intake, Holley 80570 (570 cfm) carb, CompCam roller rockers, stock fuel pump (new), HEI distributor, ported vacuum. Yeah, I know I should have built a 350 instead, but it's over and done.
It has a decent idle at 800 RPM but has a slight miss. The vacuum is steady at 15 psi. That's a bit low. Advancing the timing doesn't increase the vacuum so I assume it's because of the cam timing.
The fuel pressure is jumping wildly around 10 psi to maybe as low as zero, but it's hard to tell exactly. It seems to vary in sync with the RPM (high to low in sync with the cam lobe driving it) best I can tell
When I shut the engine off the pressure gradually drops to zero over a period of about 30 seconds. I thought it should maintain pressure? The fuel pump is a standard 2 line (inlet and outlet) design with no return line. After the car sets awhile it takes several cranks to get the fuel pressure back up to where the engine will start. Does that mean the fuel bowl has leaked dry?
Both carb fuel bowls have the float level set to where fuel almost runs out the sight hole. This is how the manual with the carb says they should be set.
The exhaust smells good at idle with no black smoke. Throttle response is fairly sluggish. It doesn't rev as fast as I think it should. A friend said he thinks the carb is starving for fuel and recommends an electric fuel pump. I think it's a carb problem, but no idea.
What do you guys think?
Jack
[edit] No charcoal cannister, just open return line.
Jack
