Hi All,
an Elky Driver from an Outpost in Germany needs help.
Can anybody tell me, how I can remove the cover from the steering post in my Elca 1975 ??? We have to repair or replace the switch for the turn signal...we can't find how to dismantle the cover - strange...!!! Do have somebody an hint for us ???
thanks and best regards...
p.S. My Elca1975 do not have an tank for the wiperwater ...??? Is this normal...? We have to install one for the german test certificate...!!!
The turn signal switch is under the lock plate, behind the steering wheel. R&R steering wheel, lock plate, and there she is...
back behind the wheel itself,there is two set of screw ,remove them and the horn pad come off. now you can get to the steering wheel bolt..:beer:
the cover that the turn signal lever sticks out of snaps into place. squeeze the outsides of it towards the lever while pulling outward (away from column) and it will come right off. reverse process to reinstall
:poke:
Lock plate tool
Do you already have the steering wheel off? There is a small ring that holds the lock plate in place, you need the tool that presses down on the lock plate so you can remove the lock ring, when the plate is off you can work on the switch.:beer:
