Hi, no additives Jasper engine with about 1500 miles on it. Started running rough so I decided to check the plugs. It is a 87 el camino with a 305 (Calif special) stock ingnition, stock carb.
From what I've read on this site the spark plug gap should be .045"and that the underhood sticker for ignition specs is wrong when it reads .035 in.
The California car could be different.
I have it bookmarked as Gap matters 0.045 FYI.
I will try that. Looking at the engine with all that smog equip seems you need to be a contortionist to get at these plugs. And small hands wouldn't hurt. 😂
If the cathode isn't squared to the pin, if it leans to one side or is off center enough, that'll be the side that constantly sparks, so that's where combustion will start which could cause that shading.
