21 - 26 of 26 Posts
Discussion Starter #21
I put a new VSS in and the problem is still the same. The speedometer didn't go over 20mph. I guess I'll have to check the cable connection on the speedometer.
Discussion Starter #22
Is there any problems adding a square tip at the end of the speedometer cable, where it goes into the transmission?
Discussion Starter #23
I'm going to try to put more lubricant in the sheath of the speedometer cable and see if that makes it work right.
Discussion Starter #24
I took the dash apart pulled the speedometer and lubricated the speedometer cable again. I also noticed that the clip that holds the cable to the speedometer was loose, so I tightened it up. I still need to finish getting the dash back together. After that I hope to test drive it if the speedometer and cruise control work.
Discussion Starter #25
I didn't get it on the road today. Having problems with getting the dash back together. Maybe tomorrow.
Discussion Starter #26
I finally got the dash back together tonight. Hope to give it a test drive tomorrow.
21 - 26 of 26 Posts
