1 - 2 of 2 Posts
Hi. Has anyone installed the Spohn frame-side engine mounts, and run them with the 98-02 Camaro oil pan, or with truck accessories (compressor clearance)
That's the direction I am headed, I am just up in the air on engine. I am thinking of going LS3, but maybe 5.3.
Thanks.
In 02'I made my motor mounts & had to notch & rebox crossmember for f-body pan. I notched & reboxed a couple of spots in frame for factory f-body ac compressor. I later learned that though you can make the variable compressors work, they won't last & swapped to a sanden with brp mounts, which gives more frame clearance.
If buying a new pan, the newer muscle car pans(holley 302-2 I think), Give needed clearance.
LS1 tech.com has a conversions & hybrids section with a g-body thread. Pretty long & drawn out though.
1 - 2 of 2 Posts
