1 - 2 of 2 Posts
i was wondering how hard/easy it would be to swap guages from an SS Elcamino/Montecarlo w/ tach into a non ss non-tach elcamino? since i have the Royal Knight decals on my elcamino, i would like to take it the rest of the way and make it complete.
Its fairly easy-------if you are replacing the clock and putting in the tach-----install the tach -make sure you also put in the inline filter that is on the firewall in the monte----and connect to the tach---the pigtails you need for the tach are in your wiring harness---there is a white one for the tach whuch suts behind your radio ---plug it in and go----if you are putting in the 115 speedo with the cluster amke sure you clibrate the speedo to match the gears you are running in the rear---Pete NYC
1 - 2 of 2 Posts
