1 - 20 of 45 Posts
So after finding a donor 05 Escalade motor, trans, ecm, under hood relay and fuse center, gas pedal & tac module. (did I forget anything?)
Now in spite of my previous experience doing wiring in previous projects I have no idea where to start....
A) what all in the original wiring, ecm and any no longer will be used electrical components can I get rid of? Will I need any thing at all from or to do with the original 83 ecm?
B) in spite of having plenty of resources available about finding how to make a stand alone harness for my swap, I don't want to forget a component, electronic device, do-hicky or whatever I may forget about for my particular motor/trans/ecm swap.
C) I bought the E.C. with all things related to and the gauge pod/panel/indicator lights missing, nothing but the speedo cable staring me in the face, so going Dakota digital, how do i figure that in?
D) I want to use the A/C again, I plan on eventually installing a Bluetooth audio/video center that can be tied into an alarm. So I don't know if what I want is going to be considered a stand alone harness or an integrated (?) one.
I'm assuming im building/assembling/getting the harness integrated into my E.C.?
I plan on writing down from the 83 E.C. schematic any components, circuits, systems etc I plan on keeping or using now or down the road and then cut anything I won't be using out. Then get my eng/trans harness situated into it?
I'm really picky about how wiring looks, I like things with correct connectors, wrapping etc. I tend to overthink wanting perfection and usually forget something simple. Now is the time since I'm sitting here stuck at home (oh bummer I get to work on the E.C. All the time) to get some things I've been putting off on this project and I'm never one to just throw money at a problem. So hit me with any suggestions, what I may forget, don't want to forget, etc.
Contructive criticism is fine too I'll take all the info and feed back I can get.
Hello,
I pulled every wire from my original 1970 350 engine out and started fresh in the engine bay with my LS swap - this seemed simpler. I used a standalone wiring harness and relay center from "PSI Conversions".
The fuse center out of the 1999 GMC donor truck was way, way too bulky for what I wanted in my engine compartment so I discarded it and ran power support for my engine from an all new American Auto Wire "Classic Update" fuse panel that fit in place of my original fuse center in the firewall up and left of the brake pedal. My original 1970 wiring and insulation was crumbling so I had to do this but your wiring might be OK. You be the judge here.
My powertrain control module (512k bytes, P01 style) sits on top of my glove box under the dash cover. The location of your ECM / PCM will highly dictate the routing of your wiring harness. I did not want it exposed under the hood and atop the glove box seemed like a logical place. It runs plenty cool enough there and its less messy with wiring under the hood.
I'm no expert on your 1983 ECM but my gut feeling is that you won't need it.
What transmission? 4L60E perhaps? Lets hope not a 4L80E because of its large size. Did you get its drive shaft?
How do you plan to control Torque Converter Clutch lockup and unlock with your transmission?
Which engine? 6.0 liters?
Let's get the engine and trans running before getting too concerned about A/C and car audio.
You realize that the donor PCM is going to need reprogramming before we can think about starting the engine? Who will be doing that for you? What software tool . . . "HP Tuners" or perhaps something else less expensive? Maybe "LS Droid" and "Tuner Pro RT" for you? These are free tools but will require you to build an inexpensive OBD2 bench wiring harness and find a three amp, 12 volt DC power supply.
I'm sure I've forgotten something but let's hear if this helps you at all?
Funny you have an 05 Escalade motor, mine is too! LS1swap.com was the most useful site for me. After getting my harness done I sent my computer to Brendan to un-lock it and delete the VATS and all other un-necessary stuff. After getting it running it was easy to find a local tuner to get it to idle with the new cam. Your A/C will operate fine after deleting the original computer, there are a few wires to delete and connect out of the loop but pretty simple. The heater valve will have to be a by-pass type, I found a 99 C10 valve worked perfectly. The gas pedal is pretty simple but you will need a welder or a friend with a welder. I can show you that one when you get to it.
I can not praise the Dakota Digital dash enough! That one large investment has been the best money spent so far! Best part is if you go with the 4L60E and use the TSS, the hole for the speedo cable is perfect for the TAC module plug to seal the hole, no mod necessary!
Feel free to hit me up, I've been there done this and wish I had this site before I had mine running!
Hello Again,
Plus a dozen votes for Joe's advice about Dakota Digital gauges. I have their HDX type and love it.
Engine mounts? I went with all Holley parts for frame mounts, headers and oil pan. Truck and presumably the Escalade oil pan might be too deep and hang too low beneath your vehicle. Between my Holley forward bias frame mounts and the Holley 302-2 oil pan, I wound up with good driveline angles to the differential, needed no floor pan surgery for my 4L60E to clear and no steering interference at the front of the pan. The Holley frame mount mates perfectly with a 2002 Camaro F-body engine mount.
I needed the Hooker / Holley Blackheart headers to clear my A-body frame rails. The LS engine original exhaust manifolds were too wide to fit inside my frame rails.
I also needed the one inch smaller power steering pump pulley from an S10 Chevy truck. This pulley fits the LS engine pump shaft perfectly while also being small enough to clear the steering gear box.
I'm also running a Cold Case LS Swap radiator and electric fans. This puts both radiator pipes on the passenger side for best mating to my truck water pump. I'm not sure what style of water pump the Escalade but I predict you will likely need a different radiator.
Hello Again,
Motor mounts are everywhere, the Holley kit looks good and the oil pan gives better ground clearance. I have the Dirty Dingo mounts and a G-Force crossmember. The PS pulley I used is from a V6 Pontiac Aztek, probably the same as the S-10 but it's still tight and the mounts are all the way to the rear. If I were to do it again I would research the Camaro and other drive systems, (which use a different water pump) but I made it work pretty good. The Escalade uses the same water pump as the trucks. The radiator is a Champion with the fitting for the heater hose re-purposed for the steam line and has the upper hose fitting on the left but the truck upper hose fits good. As far as headers go I used the Hedman Husler mid length, but it did cause a problem with the factory column shifter (which will work with the 4L60E) so I used a B&M Megashifter. There's probably more ways to do this than we can ever discuss but I can say for a fact, while running out for Pizza Hut take out a bit ago, this car makes me smile every time I hit the gas, it goes from everyday driver mode to absolutely possessed in nano-seconds!
Hello,
Thanks Rick.
I will be looking into American auto wiring and what all they may have to offer & still considering where to put the ecm but yours sounds like a good spot.
The trans is supposed to be a 4L60E (4L65E maybe by 05). The motor itself is the 5.3 and had not considered the lock up switch yet. Is that the switch that takes it out of O.D. That would normally be at the end of the gearshift lever on a truck?
I did remember to tell the salvage to get the driveshaft too.
I was aware of the reflash needed and will do nothing else and use the factory tune profile until things are all in working properly and the gremlins worked out but like hearing about L. S. Droid and tuner pro RT. Will be checking those out as well.
Thanks Rick.
You will not get very far using the "as shipped" factory tune inside your donor PCM. At the very least, a single system in that operating system called "VATS" - Vehicle Anti Theft System - must be disabled. Otherwise, the engine will not start because you are not using the expected ignition key inside the steering column. After that, your vehicle will throw many Check Engine Lights and trouble codes for the missing EVAP, EGR, Fuel System, Catalytic Converter Overheat and rear O2 sensors, and others I can't remember. Your tire height will also need to be calibrated to keep your speedometer and odometer accurate. Its best to kill off / defeat / disable and change these things all at once inside your PCM.
I highly, highly recommend finding another PCM of your type in the junk yard as a spare. Around here, they are $38 and it is good insurance in case you "brick" one though that has not happened to me yet. I have one "0411" type installed, plus another 0411 and two of the "896" variety tuned and sitting on a shelf. The only benefit to the 0411 over the 896 is that the 0411 logs parameter ID's slightly faster than the 896. And the only reason I have four of these is that I picked them up for cheap on half price sale days.
Don't remove the original stickers on these PCM boxes because they tell your tuner person a lot about the hardware guts inside each device. Its the last 3-4 digits in the "Service Number" that I'm referring to here.
The PCM controls lockup of the TCC but you need a secondary switch built into the brake pedal switch to command unlock. Its takes a roughly $23 plus shipping switch from PSI Conversions.
All of this was fixed when I sent my computer to Brendan at LT1swap.com. $75 bucks and returned in 3 days ready to run and get tuned. Lock-up is easy and will be controlled by the 05 model computer and can be tuned, mine is set at 42mph to keep the car from bucking to the cam lope. If your car had a 2004r trans you will already have the lock-up control wire at your column. If not all that is needed is to install a brake switch from a 2004r equipped car and attach 1 wire and done.
I agree with Joe about using Brendan at LT1Swap.com. He does good work at a very good price and has an excellent reputation. I'm simply a nerdy tinkerer and wanted to learn how to do it myself. Big however, I did not like paying the rate for this to get an HP Tuners skilled person to do it after paying it for my first two 896 PCMs. Finding that guy locally and taking him my PCM's also got old but he did do good work at a fair price.
Once LS Droid came online dependably for reading/writing and I learned enough about how Tuner Pro RT works, it was a simple matter to build a bench OBD2 harness and find a three amp power supply. Now I can play "Doctor Frankenstein" with the operating system in any of my PCMs for free.
And hey, just curious. Are you in a state that has strict emissions control laws?
Thanks Rick.
Thanks Rick.
You won't need a truck driveshaft, your original will slide right into the 4L60E ro 4L65E whicever one you have. You will have to shorten the original shaft a bit, it will vary depending on the motor mounts you use. If you run the original cam tuning isn't even needed unless you want to unlock the power these motors have and were de-tuned to make sure it wouldn't break under warranty.
For us guys that are more mechanical and very much computer illiterate Brendan is the guy to go to! I have learned a lot about the process but still don't know enough to do it myself. I drove my car to a local tuner. Yea, the price was pretty high but the re-tune price if I need to is pretty cheap!
Discussion Starter #13
Joe. So glad you chimed in and I'm sure you'll get a P. M. or two from me and Thank you so much for the offer. A few more three lettered things (Tac, Tss,) for me to look up and know. I will note that c-10 part. And luckily have a little wire feed welder for that pedal bracket.
Discussion Starter #14
Hello Again,
Clearance... Thats why guys put smaller ones on. Thought it might be to reduce flow a bit.
TAC=throttle actuator control, TSS=transmission speed sensor (to the speedo)..
Let me know and I'll try my best to clear the fog on the road ahead.
Exactly, however it doesn't reduce flow but just the opposite, the pump spins faster. I added a extra cooler and after a couple years no problemo!
When I did my 79 my harness fix it guy told me to get an 06 Monte Carlo pedal. It fit with 1 hole to drill. The bottom hole lines up with the existing bottom hole in a 5th gen. Drill the top hole and pedal is done.
ACDELCO 25830024
TSS is also known as the VSS (Vehicle Speed Sensor) in later vehicles. Powers the speedometer and ABS. Mounted on the tail shaft of the transmission.
Spend the money and go with a Painless wiring kit. It will save time, money in the long run, and be functional when you are done.
1 - 20 of 45 Posts
