My 67 el camino is currently dead in my garage.
For awhile I have had issues with the car not starting after getting hot. After an hour or so it would fire up. This week the car dead cold cranked like normal for about 3 second, turned off the key, when I went to crank again, nothing. No crank, no headlight, no guages, nothing on the voltmeter.
I thought before the starter was going bad, but now I'm thinking its an electrical issue elsewhere.
Nice fresh thick ground from the battery to the block. To reasure the ground I took a jumper calbe from the negative terminal to the frame. No change at all.
Thoughts, tips, mobile mechanics?
