1 - 2 of 2 Posts
I found out one of my buddies has a TH400 in his shop that he's not going to use and he said i can have it, butI have a couple questions about putting a TH400 in a 5th gen I know this is a better tranny than the TH350C plus i get away from the lockup converter. I've heard putting in the 400 is a pretty tight fit and was wondering about this? Also the 400 does not use a cable for the kickdown like the 350 does what is required for the kickdown to function? I know that the 400 is longer and that i will need to shorten the driveshaft, which is not a problem. Also what about the crossmember, will the 350 one work just move it back or will i need another one? Thanks for any help i can get.
camino81
It fits just fine. It is not a tight fit.
The kickdown is activated electrically. The ECM controlled TH400 gets a signal from the ECM. You can use a kickdown switch mounted to the throttle linkage instead.
Don't forget that the yoke needs to be changed too.
You'll need to modify the crossmember, and the mount is different too. You can probably get a g-force crossmember that will fit too.
I used to have a TH400 in my 79 Elky. I've still got the modified crossmember and drive shaft.
:mrgreen:
1 - 2 of 2 Posts
