'84 Conquista, factory console shifter. The shifter bowl on the column does not move all the way around when the floor shifter is moved to park, so the key will not move to lock. The bowl can be easily twisted the rest of the way so the ignition will lock and the key can be removed. Also the dash gear selection indicator does not show correct gear. When in drive it usually displays N and can be moved back and forth by twisting the bowl. I have read all through the threads related to this problem. I understand there is a connector between the column shifter and the floor shifter. I am unclear where the adjustment needs to be made to get the two in sync. Is it underneath at the trans or in the cab at the bowl? If at the bowl, how do you access it?
Thanks,
Don
Thanks,
Don
