Okay, I've got a chance to swap out my trusty TH350 and install TH200R4 instead. I got it dirty cheap, so that's the way to go. I have read all sort of forums and searched a lot of things about this swap. I tried our forum too, but there are too many threads...
I got '70 El Camino and what have I understand is that only thing that I need is new cross member, right? TH200R4 is from '80-'90's Chevy van.
Friend says that I also need a some sort of adapter to my speedometer?
Deputy Director Supporting Member
You will need to purchase a lock-up kit for the torque converter to wire in to your '70. You may need to adjust the coolant lines where they hook into the transmission....may just need bent a little to bolt into it. FYI change out all those things we discussed in the other thread abut the TH350. You'll probably need some other things, too....
