I have a TH350C in my 81 camino and was wonder what you guys thought about these trannies, are they worth putting some money into, or should i just get a older non-lockup TH350? Thanks for any info
camino81
well, almost everyone on maliburacing.com uses the TH350 or TH400....reason being they either are, or can be very strong trannies....i used to hate my th350 till i found out how strong it was, i'd say keep it, it can certainly handle a TON of power, and it'll give you some good runs, maybe consider a new tourqe converter though.
I've heard good and bad about the 350, but i was wondering about it being a computer controlled lock up converter transmission. I know B&M sells a lock up control module at summit and was thinking about trying that since i no longer have the computer in the car. I've also found a decent lockup converter and a shift kit, but haven't bought anything yet. The tranny still worked fine when i pulled it and i'm not sure if i should stick with it or get a non computer non lockup tranny.
camino81
I like the 350, I think it's a good dependable trans that will take a moderate amount of abuse. I guess it would depend a lot on what your plans are for your Elky. Do you plan on dropping in a high horsepower/high torque engine, if so you might want to upgrade to a 400THD. Are you looking for better gas mileage? Then you might want to go with a 700. An automatic trans swap is a fairly easy job. What you can afford now or what you might want to do later can be accomplished when time/money permits. I have a 350THD in my Elky with the original 305 motor, it's worked just fine now and there's 98K miles on the drivetrain. My plans however are to drop a new motor in soon, hopefully a Big Block, when I do, I'll be switching over to a Borg Warner Super T-10 4spd. If it was me, I'd stick with the trans you have until your ready to swap the motor also, then I'd consider something like a 400THD from TCI (streetfighter).
well i'm only going to have a mild small block 300 horse or so, so i think i'll just use the tranny i have now and when it goes i'll get a built 350.
camino81
