Well Folks thru some investigative snooping around , I had a hunch that the ground was the problem :secret: ... Because I had checked all my fuses , they were OK and I checked around with my test lite and I had PLENTY of power ... So I replaced ALL the ground wires and when I looked at ALL of them , they has some white powdery corrosion on the backside ... So I realized this GUNK ENGINE DE-GREASER had gotten behind all of the ground strap flat surfaces and corroded them causing NO GROUND :dontknow: Damn I'm good :beer: ... Soooo I wire brushed all the flat surfaces and put new flat washers and some Di - electric grease and Hoopy - Dee - do , my radio came on and the gas gauge started gauging and even the tack & tack lite all came back alive :inlove: Damn I'm Good for an Old Geezer :nanawrench: ... so Folks be careful when using Engine Degreaser on the firewall and fenders it might cause your ground to UN-GROUND ...Thanks the Geezer:nanawrench:
