1 - 3 of 3 Posts
i have a 305 out of a 77 camaro in my 85 camino i just swapped out the intake and carb a few weeks ago to a edelbrock performer and a rochester quadrajet carb, ive had no problems until recently when i hammer the throttle the car stalls out then comes back to life and accelerates any ideas on what the problem might be?
Spring adjustment on the secondary top plate is set too loose. If there is a rod going from the choke pull off to the secondary air flap the pull off is bad. That is the two ways they controlled the opening rate of the top secondary flap. Accelerator pump usually gives you problems on cold start and stumbling when driving on the primaries in a q-jet.
1 - 3 of 3 Posts
