Looking for a Tic-Toc-Tach to fit an '78-'84 El Camino/Malibu/Monte Carlo, I think they're all the same. I've got the factory clock but would like to replace it with the Tach/Clock combo so I'd also need the blue plastic bracket that attaches it to the gauge cluster.
:poke: just incase :secret:
you decide you don't need a 36yr old clock, that probly needs fixin,
and might wind up costing more than a branew 8k tach for $109..
https://www.mikesmontes.com/New-81-85-tach-8K-RPM_p_803.html
back in the olden days, if I wanted to know what time it was,,
I never looked at the clock in my car,, it was allways wrong...
:texas:
All 78-85 tachs will fit... however the 78/79 tach does differ in appearance than the 80-85 tachs..
78/79 tach below...
and the 80-85 tach..
If you have the computer disconnected in an 84, will the tach work the same or do I need to replace something else. I've thought about replacing the filter that Mike's Monte's has listed but wasn't for sure. Mine has a stock type HEI with edlebrock carb. Nothing connected to computer.
