Hello for once my el camino is running fine but my s-10 is another story.I bought this truck off craigslist a few days ago the previous owner said that she took it to the shop and they said that the timing gear had sliped.It ran very rough and had little power but I drove it home a few miles.It has new plugs/wires, fuel/air filter.I tried to adjust timing by advancing and retarding the distributor but to no avail.so I tore down the motor to the timing gears.After removing the timing cover I inspected the gears and neither was worn also factory markings all lined up at TDC.I did notice that when timing gears where lined up the distributor rotor was facing 180 degrees from the number one plug so I loosened the distributor and turned it ,I never removed it just rotated housing.Now with the timing gears lined up and the piston a tdc and rotor facing number one plug I atempted to start it and motor just backfired ,so I turned the distributor back around 180 and it still wont start but it sound much closer to me.It doesn't make any sense to me any ideas.It was running with rotor facing that way when i got the truck also i did check for vacume leaks but i did not find any the motor is a 2.5 4cly Thanks you guys usually are a big help
