1 - 2 of 2 Posts
Im going to UTI right now and im able to align my tires at school for free.
Does anyone have the Specs for 73 elco.?
the outsides of my tires are wearing out quick. i stopped driving until i can get everything straightened out.
Forget the factory specs, I bet your running radial tires. If so do this: Factory spec for castor is negative to a 1/2* positive. Pull your casters as high as you can, if you can get a full degree or a little better go for it. Keep you castors even left to right. Camber were usually high back then but drop it down no more then 1/4* positive, or if you have rather wide tires go a 1/4* negative. Outside wear is means too much positive camber anyways.
The factory toe range is 1/8-1/4" toe in. If your front end is new and tight, go no more then 1/8" total toe. If you have urethane bushings drop down to 1/16 or less.
You be very happy with theses settings.
Mike
1 - 2 of 2 Posts
