:? I have just dropped my front end with 2" dropped spindles. I had 235-15's on the front but they rub now. Any suggestions on tire and wheel size that will not rub?
Update 6-6-2003- My local tire store recommended 215-15's and they fit fine. Thanks John for the advise.
Welcome to ECC 83NHElky!
Where are the tires rubbing? Frame, Sway bar, Fender? I also have 235/60/15's on my 87 El Camino with stock spindles and they will rub if I turn them far enough.
:mrgreen:
Reply-
Hi Ernie,
They are rubbing on the inside of the inner fender. When I look at the tire it sits about 1 inch into the fender well. So when I go over a bump they bottom out.
Thanks,
Allen
Moderator
I run 225/60s. Before I lowered the front I ran 245/60s on all corners. The 245s rubbed slightly at stock height. The 225s fit great.
