How to Install Hayden Ultra-Cool transmission cooler in series without Cutting steel transmission lines?????
Suggest that you read the installation instructions that came with the transmission cooler from the manufacturer, then come back with any specific questions if problems arise.
X2 !!! Read the instructions !!Suggest that you read the installation instructions that came with the transmission cooler from the manufacturer, then come back with any specific questions if problems arise.
Exactly What the instruction states and Thanks A million!BTW guys the new one probably won't tell you how to use both. It will say to cut the flared ends off each line and connect rubber hoses to each and the new cooler.
So reading the directions most likely doesn't answer his question.
Pictures Will be Soon Trying to Clean up elk this weekendmalibuchevyz - don't forget to post pics of your project
Sounds Good Think this is option #2 if i cant get second pre bent line in!!!
