1 - 2 of 2 Posts
I have a 700r4 with the push in style dipstick in the Elkie. I need to move the the dipstick for clearance reasons. Are any of you guys using the flexible fire wall mounted style? After looking at all of them that are available I'm wondering if there is one brand better than the others as far as leaks at the trany case? Also should the tube boot seal be replaced with the new dipstick?
Thanks for any input, Ang.
i have only seen one of those used and was a pain to fill.yes you replace the sleve any time you change the tube.they make several different tubes from cars and trucks that may give you the clearance you need
1 - 2 of 2 Posts
