Hello,
Rather than tap into power at the fuse panel Accessory port, I'd suggest finding the radio 12 volt positive wire and tie in there. The radio should be powered at both the key "ACC" position and the key "ON" position. This method will also supply your Dakota Digital cluster with electrically quiet power for no noise interference with the gauges.
Are you missing the fuse in your panel for A/C air conditioning?
