well after thinking about it and talking to more people im even more torn. finding a decent GN motor doesnt seem easy and im not looking to rebuild a motor in 20k miles. people who had GN's said the turbos caused alot of issues.
im starting to lean more toward the idea of a 350. because for $4500 i can have:
Chevrolet Performance 350ci/330HP HO Turn-Key Engine
Designed by GM Performance in-house engineers to provide maximum power for your hot rod dollar, you won't go broke finishing a project with this 350 HO Turn-Key crate engine. It's packed with all the features you need to get a reliable 330 horsepower and 380 ft/lbs of torque from a time-tested combination of new GM Performance Parts.
Note: Accessory components arrive unassembled for ease of installation.
SPECIFICATIONS
Bore/Stroke 4.000" x 3.480"
Maximum RPM 5500
Camshaft Hydraulic flat tappet (part #24502476)
Camshaft Duration @ .050" 212° Intake/222° Exhaust
Camshaft Lift .435" Intake/.460" Exhaust
Compression Ratio 9.1:1
Pistons Cast aluminum (part #12514101)
Connecting Rods Powdered metal (part #10108688)
Crankshaft Nodular iron (part #14088526)
Cylinder Heads Cast iron Vortec 64cc (part #12558060)
Valve Size 1.94" Intake/1.50" Exhaust
Flexplate 14" (part #14088765)
Rocker Arms Stamped steel 1.5:1 (part #10089648)
Water Pump Cast iron, long (part #88894341)
Ignition Timing 10° BTDC @ 700 RPM
Recommended Fuel 92 octane
at this point she wont be my daily anymore, but a lot of fun
