I have an 85 choo choo. Recently I noticed my driver's side rear turn signal was about 75% less bright than the passenger side. The front turn signal light is fine. Also when I have my headlights on the left turn signal stays solid and won't flash but the right turn signal is fine.
Anyone have any thoughts on troubleshooting? thanks
thanks for the help. I changed the bulb in it and I'll double check the wattage. Also will check all grounds. How can you tell if the ground in the plug is bad? simple corrosion?
