1 - 2 of 2 Posts
Question #1. I discovered that the lockup solenoid does not work. The switch has one orange wire going to it, The replacement switch has two wires, one red and one black. I "assume" the red is power and black is ground. If so, can I just connect the ground to any bolt in the valve body and red to the orange wire??
Question#2. I have installed a FI Tech FI system, on a Edelbrock intake and used their three place cable mount. The throttle works great and also the cruise, but I cannot get the TV cable to work, When I install it, it limits the travel on the throttle cable. Is this TV cable or just a "kick down cable" ?? I have eliminated all the ECM "stuff" and plan to use the B&M lockup control to actuate the solenoid,. Thanks in advance for any advice.
1 - 2 of 2 Posts
