21 - 22 of 22 Posts
wtg JR
at least it was clean oil..
i'v seen several guys with the same problem
some with hot oil spraying around in the cab..
they do make oil/fuel gauge isolators now days ..
put some oil pads under the carpet,
when its mostly gone then soak it down with carpet cleaner, over clean pads..
I keep a oil line kit in the tool box..
You will be amazed what a red can of "Brake Kleen" can do to clean up those oil stains in the carpet. They will be gone.
Just make sure you let that spray air out for a while with the windows down and doors open. Otherwise, you will soon be "tasting sounds" or "smelling colors" in hallucinations.
21 - 22 of 22 Posts
