I'm trying to evaluate a V8 engine for transplant, but I am wholly ignorant and need some help. This is for my 85 El Camino 305V8 with (I think) 200c trans.
I need to replace the current 305 V8. Not looking for max power here, just a good cruising engine that gets reasonable gas mileage and is very streetable. I won't be racing it or towing anything.
My mechanic has a 1975 2 bolt 350 (I'll get the date code and stamping info to confirm) that he pulled a few months ago from a customer's car and replaced with a crate engine. It's a short block, more questions about that in a bit.
He says it has about 2K on the clock, customer ran it too hard and caused damage to #2 piston skirt. It's bored .060 over and balanced. No ridging on the top of the cylinders, the bores look very clean. Mechanic says he'll replace the piston. It's a steel crank, don't know if it's forged or cast, I'll find that out, is either one OK?
One of my concerns is overheating because it's .060 over. Among the freeze plugs installed during the build, one of them has a lead insert that would melt if the engine ever overheated, and it's intact. I've never heard of this type of freeze plug, is this for real? Is a .060 overbore inherently prone to overheating?
About the short block: mechanic says using the 305 heads on the 350 is a good combination for power and he'll grind the valves on my heads. He also says the 305 4 BBL carb and intake will work well on the 350, and can be later switched over to a FI system easily. True?
Lastly, I'll probably be ditching my current 200C transmission and getting a 700r4, in case this makes a difference on the 350.
Thanks in advance for any and all help!
